Primavera P6 - Interface Problem ("Add Resource")
19 years
This usually happened on a Primavera client installed locally into your machine (and or standalone installation) using dual or multiple screen for P6 ver 16.x down. When P6 was opened on dual or multiple screen, while moving around the pop-up windows into different screen (specially resource assignment and relationship) this will be saved on users profile when exit to the applications.
When the user tried to open P6 on single screen after the above event, the pop-up window for either resouce assignment and relationship will not be visible because the last users profile event save was on a multiple or dual screen therefore the pop-up window is not visible.
Workaround:
Option 1: If you have access to connect to other screen or monitor, open P6 and move all the pop-up window into main display then exit to Primavera application. Disconnect the other screen and open again the P6 application and try to open the pop-up windows that missing if they are now visible.
Option 2: If you don't have access to connect to other screen or monitor but you have an admin rights, create/ add a new user. This will create a users profile with primavera default. Logout and login to the new user created and you will have the pop-up window visible.
11 years 4 months
20 years 6 months
Are you using Dual screens or using it over a virtual desktop (eg. Citrix?)
16 years 3 months
make sure that you have the proper rights to add a resource
