I am on 19.12, Zoltan, and P3 format has gone. Not sure when! I still have a working version of Suretrak. Amazing software for the time. Still very impressive twenty (?) years after development stopped
16 years 3 months
Member for16 years3 months
Submitted by Zoltan Palffy on Thu, 2020-11-12 16:26
Not any more. You used to be able to export a P6 file in a format that P3/Suretrak would read. You could then open the file in Primavera Suretrak from 1990, and just do CTRL+ or - to zoom the layout in or out.
Worked perfectly
16 years 3 months
Submitted by Zoltan Palffy on Tue, 2020-10-27 13:53
16 years 3 monthsthe work around is to use the
the work around is to use the xer to P3 converter then bring it into suretrack
21 yearsI am on 19.12, Zoltan, and P3
16 years 3 monthsDavid I am using P6 version
David I am using P6 version 8.2 amd I can still export an xer file to a P3 format and then read that in suretrack
21 yearsNot any more. You used to be
Worked perfectly
16 years 3 monthsthe only work around is to
the only work around is to make the row height and text larger
16 years 3 monthsth eonly work around is to
th eonly work around is to make the row height and text larger
