Imported XER showing as 4 separate items in the EPS
8 years 1 month
Thomas,
Sounds like the WBS on the import file is corrupt & instead of being seen as a child of the Project they are not getting the reference to the correct project ID & then showing as additional projects.
I have seen this a number of times, but usually when manually editing the WBS to add additional values.
When you delete the project that they are supposed to be under then the additional records should also be deleted.
This can also be caused by having certain punctuation in the WBS codes that have been added ouside of Primavera.
If you are able to share the file then I could have a look to check for these errors if you want.
EDIT - Apologies - never noticed that you had fixed it.
Steven
19 years 1 month
Hi all,
We think the problem has happened due to a Microsoft project import and it not having a parent to the included WBS. Solved it by creating a new empty plan and copying these into it.
Thanks for the suggestions
Thom
20 years 6 months
If the single plan you are looking at contains relationships to other projects, then a record of those proejcts will also exist in the XER and may get created when you import that XER. It may also be due to corruption of the data for the project, creating orphaned records that are also transferred in the XER file.
7 years 7 months
I think this problem because of the project WBS.
You have 4 Project Node in the WBS table under the same Project ID.
You may also have no parent for these 4 WBS Elements.
Be sure you have only one Y under the project node in the WBS Table.
Be sure that all WBS elements have a parent except the project itself.
16 years 3 months
only suggestion would be to open with the parser and recreat it
5 years 5 months
Hey Tom,
I wouldn't mind taking a look if you want to send it to me. The only thing that I can think of is that they exported all 4 files at once, and you have them all open at the same time upon import. But if you want to send me the file, I can take a look.
pat@jobsessions.com
Pat
