3. Under the Select Subject Area to the left select "Äctivities
4. Under the first Option box set Paramater to "Any of the Following"
5. "Where" set Paramater to " Activity Name" " Starts with" " IFA/IFR/IFI"- the operator "OR" should be used for different Lines this shall be as per the line in the p6
6. Then in the output condition box the parameters as " Activity Name" "=" Paramter Value "WBS Name"" operater "&" Äcivity Name".
[[wysiwyg_imageupload:7436:]]
16 years 3 months
Member for16 years4 months
Submitted by Zoltan Palffy on Mon, 2020-06-08 13:51
15 years 7 monthsSelect Global change under
Select Global change under Tools
1. Create a New Global change
2. Open the New Global Change
16 years 3 monthswhere is the text of the
where is the text of the changes ?
15 years 7 monthssure Sir Mr Zoltanthist is
sure Sir Mr Zoltan
thist is what i had in my schedule
Then navigate to menu -> Tools-> Global Change-> modified as -> below
commit changes below is outcome
i require a hyphen that i inserted using the find and replace.
Thanks.
16 years 3 monthsok can you tell us ?
15 years 7 monthsThanks guys i found it i
Thanks guys i found it i understood want i was doing wrong.
