1. 1st what you are talking about is a right issue. The rights do not come with an xer file but is a function of p6. They only way to make this a read only is to give them access to your system and set ther rights as read only.
2. even if they change your information its not what you sent them. Is there something that you dont want them to see such as costs or uints ? If so you can copy the project and strip those items easily prior to giving them the file.
3. Let them change whatever they want its stiil not YOUR schedule.
20 years 6 months
Member for20 years6 months
Submitted by Santosh Bhat on Fri, 2019-08-02 09:14
Ask them to buy a copy of a tool like Schedule Reader or similar. THis way they can inspect the XER file but cannot modify it.
Unfortunately, its not possible to set rights on read/write within an XER File. If a person gets an XER file, they can upload into a P6 database and do as they like with it.
One method you can defend youself. is to note the Date & Time the XER file was produced. If anyone imports the XER file into any other system, the "Last Modified Date" in their P6 will show either a) The date/time the XER was imported into their P6 databases, or b) the date/time they made changes AFTER importing.
You could argue then the modifications made AFTER your XER timestamp are no longer respresentative of the data you supplied them
20 years 6 months
Member for20 years7 months
Submitted by Zhang Haixiang on Fri, 2019-08-02 03:52
16 years 3 months1. 1st what you are talking
20 years 6 monthsAsk them to buy a copy of a
20 years 6 monthswhat will happen if the
what will happen if the change the schedule? what is your concern if they change the schedule?
will they print it out and give you to sign-off?
You give the schedule to the client for what? review/apporval, or just reporting progress?
Anyway there is no way to protect a XER file, it is just a TAB seprated plain text file.
