Lag and Original Duration
16 years 3 months
Santosh has the solution
20 years 6 months
  1. Open the project
  2. Select FILE>EXPORT>XLS
  3. Select both Activities and Activity Relationships
  4. The default Export template should be sufficient for what you need
  5. Select a locaiton to export the XLS file to
  6. Open the XLS file
  7. There is one tab for the activity infomration where you'll find duraton
  8. There is a second tab that lists all Relationships inlcuding lags
  9. Use VLOOUP to match the predecessor ID in the relationships tab to the duration in the activity tab
15 years 9 months
Hi Larry
You can use the 'Reports' feature for all the relationships in the schedule. Also the lags.
Go to Tools < reports and then select report AD-02 activity relationships.
Regards Johannes
