Exporting P6 Project to Import on Laptop
16 years 3 months
use the bckup command then use the restore command to backup and then restore the entire database ESP and all
8 years 1 month
Jeff,
Zoltan is correct - the EPS is not exported with the XER file (or XML for that matter).
If you know the EPS code types & you create the types in the new EPS that you are going to import into, then you can import the code values - but the type has to exist already in the new database for this to work.
You would need to know what EPS Code Types are included in the XER file - before importing into the new database.
You could change to Global codes, but this then removes some of the benefits of having them at EPS level.
Steven
16 years 3 months
the EPS NEVER comes with an export of an xer
you can backup the whole datbase and restore it to the new laptop
if you give me your email I can give you setp by step instructions for you are using MS SQL as your underlying database
