Primavera holds the numbers in two places, and they do get out of synchronisation.
You should check the units in both the “Activities” window and the “Resource assignment” windows
When you do a resource profile/spreadsheet, the numbers come from one table, the Activity spreadsheet/profile and ALL earned value data comes from the other.
16 years 3 months
Member for16 years4 months
Submitted by Zoltan Palffy on Wed, 2018-09-19 13:57
16 years 3 monthsunder edit user
under edit user preference
turn your decimal places on
Time units tab
9 years 8 monthsThanks David, found it is
Thanks David, found it is exactly the problem.
Going to delete resources and reload as I guess this is the only fix.
21 yearsPrimavera holds the numbers
16 years 3 monthsmake sure your filter is set
make sure your filter is set to ALL activities
