WBS is not sorting correctly in Activities
20 years 6 months
Justin, no problem, and thanks for following up with a response.
7 years 2 months
Santosh,
That worked perfectly.  Thank you very much for the help.
20 years 6 months
Justin, in the WBS view, click on the WBS code column header, note that the Triangle will cycle through up, down and then into the Hierarchical display. The default sort for WBS in the Activity View is your hierarchical order.
You'll need to do the following
1) Change the WBS view to have the WBS code column sorted by Hierarchy
2) Use the Arrows (likely to be on the right side of the screen) to order the WBS codes into your required order. Note you can also click on any line and then press CTRL+Up/Down/Left/Right arrows to shift these about.
3) Leve the Acticity View Grouping to be by WBS.
15 years 11 months
Don't use WBS Path instead Group and Sort by Default. It will organize into Hierarchical.
7 years 2 months
Thanks for the input, sorting by WBS path gets it in the right order but then I lose my WBS names and the columns on the left.
15 years 11 months
The WBS Layout seems sorted by Code in Ascending Order while in the Activity Pane WBS is sorted in hierarchical order.
Try to organize the WBS layout in Hierarchical Order.
Regards.
