Thanks for the suggestions. They didn't solve the issue, so I redirected to my previously saved database. I'm going to make a practice of copying / archiving it each night just in case this ever happens again.
7 years 4 months
Member for7 years4 months
Submitted by G.P.Willikers on Mon, 2018-07-23 17:03
16 years 3 months
Member for16 years4 months
Submitted by Zoltan Palffy on Mon, 2018-07-23 14:35
Solution: Disable bar-necking in the Activity View.
Select View, Bar
For each bar that has "Display" selected go to the "Bar Settings" tab.
De-select both "Calendar nonwork time" and "Activity nonwork intervals" under the Bar Necking Settings Option
Click "OK"
If AVAA0 error still happend then delete the layout
Printing options are also part of the layout and may be a source of the problem.
Printing issues can be caused by not having the printer's driver installed on the PC.
First make sure that there is a printer driver installed.
Second verify that a default printer is set
Third try to print to a PDF printer
If the error occurs in Page Setup the scaling options may need to be changed. Use the "Fit to" scaling option instead of the "Fit timescale to" option. The "Fit to" option should have values, not zeros for the pages wide and tall settings.
16 years 3 monthsthats basically my reply
20 years 6 monthsThere is an article on
There is an article on Oracle's Support that might cover this issue. Doc Id. 2145705.1
16 years 3 monthsthats a good idea
thats a good idea
7 years 4 monthsThanks for the suggestions.
16 years 3 monthsits definetly a layout
its definetly a layout issue
