Thanks. That is certainly true. I suppose I just wanted to know if I'd overlooked something obvious (eg. "that clearly won't work because the .sqdb file is only one part, and there are many other files in memory that recording an instance would need" etc) and at least without those comments I can proceed to the testing knowing at least there's a possibility.
16 years 3 months
Member for16 years4 months
Submitted by Zoltan Palffy on Wed, 2018-02-07 13:51
DAvid's Big Book of data processing says only one thing on page one:
IT IS NOT A BACKUP UNTIL YOU HAVE TESTED THE RESTORE
So, your solution is ok, BUT until you have moved the file to another empty P6 installation, and been able to open your projects, it does not count as a backup......
7 years 9 monthsThanks. That is certainly
16 years 3 monthsyou can also do this through
you can also do this through a command line batch file
21 yearsDAvid's Big Book of data
