The option to import XML is greyed out. I did not have any luck with the MPP to MPX converter.
I did find a solution. I found an application that converts XML to MPX. I was able to export the MSP project as an XML then convert it to MPX and import it into P6 that way.
I had to try this process a few times since I was having issues with logic and dates in the import. I was able to fix everything by setting a calendar to all of the activities in MS Project.
16 years 3 months
Member for16 years4 months
Submitted by Zoltan Palffy on Tue, 2017-11-14 14:28
MS Project no longer gives the option to save as an MPX file.
There is a convertor kicking around that apparently convers MPP to MPX, but I cant get it to work (Claims I dont have MSP installed, when I definately do)
Im having the same issue as you Sonya, I have exported the XML from MSP, but when I import (using the Import Microsoft Project XML option) I get an error that claims the import succeded, but with errors.....and then I cant find the imported file in my Project list!
For some weird reason, I also cant Export an XLS file from P6, gives me an error about the database or something :(
"Primavera P6 - XML" and "Microsoft Project XML" are two different file types. Do you have a Microsoft Project button available on the Import Format window? That's where you should click, then select XML in the pull-down list.
15 years 8 monthsHi,You can try the convert
You can try the convert tool from Primavera to convert from mpp to mpx. You can refer to instruction here https://doduykhuong.com/2016/02/04/convert-microsoft-project-mpp-to-mpx-to-import-to-primavera/
16 years 3 monthsthank you
thank you
9 years 4 monthsThats the one I used last
Thats the one I used last night, works a treat.
22 years 9 monthsSonya,thank you very much for
Sonya,
thank you very much for the link to taktone; the converter and the viewer are great!
Alexandre
7 years 11 monthsTaktone: Project File
Taktone: Project File Converter
https://www.taktone.com/Home/PFC
16 years 3 monthscan you please supply that
can you please supply that link to the xml to mpx cpnverter please
7 years 11 monthsThe option to import XML is
16 years 3 monthssave the project to an MPP
save the project to an MPP then run the mpp to mpx and import the mpx
there are at least 2 mpp to mpx convertes out there
9 years 4 monthsMS Project no longer gives
Sorry for hi-jacking your thread.
18 years 11 monthsSonya,"Primavera P6 - XML"
Sonya,
