Primavera P6 Reports edit/format
21 years 11 months
Good Morning all
I'm using P6 V16.2 I cannot get a report to come ut of it formatted as I want it. It is a simple report showing planned units for laboour and materials, when I export it to excel as an xls file as opposed to a csv file format, the data on each line is just one long line of text why?  In all previous P6 applications it ihas come in as a tabular report in the correct columns etc.
The way I have got round it at themonment is to take the file extension off it, then dumo it into wordpad, the import the text file back into excel, seems a ponitless long winded way of doiong things, is there a setting somewhere I am missing
Any help would be appreciated
Thank you
Rob
16 years 3 months
why dont you get your all of your columns set up in your data window and then right click and select export to excel. You can then use the trim function in excel to remove the -014.
9 years 10 months
Thanks v.much
21 years 9 months
Hi Eamonn,
As far as I'm aware, it cannot be done in Report editor.
=jerome
9 years 10 months
Thanks very much Jerome, I appreciate that!
Can this also be done any alternative way? I know how to get the basics of what I need but would like to know more of the functionality, like could it be done in the Report Editor or is it only through using the steps you outlined above in relation to my original query?
21 years 9 months
Eamonn,
Create a User Defined Field called "Primavera ID" of Data Type "Text" and then apply Global Change. Under the Then section, add the formula
Primaver ID = LeftString(Activity ID, 9)
where 9 is the length of characters you want to keep from the example you gave and this assumes your activity IDs are all of same fixed length.
Apply Global Change before running your report (remember to modify your report template to include this new field).
=jerome
http://plannerstips.blogspot.co.uk/
