Microsoft Project Member for 22 years 9 months Member for 22 years 9 months Submitted by Alexandre Faul… on Fri, 2019-10-18 11:38 Permalink Nathan,make sure the lower Nathan, make sure the lower level in the timescale is not larger than the upper one: for instance upper level = week, step: 1 is not compatible with lower level = days, step: 8 if the problem is not this one, I suggest you re-install MS Project Alexandre Log in or register to post comments
22 years 9 monthsNathan,make sure the lower
Nathan,
Alexandre
