// "In "general use," one can't reliably presume a correlation between the ID sequence and the logical sequence." //
Understood. In this case it's a factory production schedule that by fiat gets used in a particular format over and over so I have pretty tight control on how it's sorted.
In "general use," one can't reliably presume a correlation between the ID sequence and the logical sequence. Still, as you've explained, this certainly seems to offer a bit of streamlining for that particular (ZFF) issue.
Rgds, t
7 years 1 month
Member for7 years1 month
Submitted by ThinAirDesigns on Thu, 2019-05-02 23:14
As to its usage, I actually just successfully used it to modify your ZFFImpose function. I've been creating schedules with tasks such that I needed to loop through multiple times to get all the float out of all the faux-ZFF relationships (programatically constraining one task simply moved the float up to the previous task requiring another run through).
My previous schedule had a known number of these relationship layers (3) so I just looped through your code three times. Now I have a schedule that the users might add an unknown number and I needed a more elegant solution than my previous clutz.
Going through backwards allows your code to now remove the float as far up the chain as needed in one go-round.
I'm a programming hack, so you might have come up with a cleaner solution, but this works slick as a whistle as written.
6 years 2 monthsThanks Tom for the code!
7 years 1 month// "In "general use," one
Thanks again.
JB
18 years 11 monthsJohn,Glad you got it
John,
Glad you got it sorted.
Rgds, t
7 years 1 monthThat's it Tom ...
That's it Tom ... THANKS.
The task.count property was the secret and this link didn't list it for whatever reason:
https://docs.microsoft.com/en-us/office/vba/api/project.task
THANKS (for both the original code AND the mod)
JB
18 years 11 monthsHi John, this will do what
Hi John, this will do what you ask, though I can think of no good general-use case. Good luck, tom
Dim t As Task
Dim i As Long
For i = ActiveProject.Tasks.Count To 1 Step -1
Set t = ActiveProject.Tasks(i)
If Not t Is Nothing Then
'Your Code Here
End If
Next i
End Sub
18 years 11 months[Delete duplicate]
[Delete duplicate]
