ALAP constraint behavior question
22 years 9 months
Tom,
you are perfectly right, SF link is only a workaround; it does not answer the fundamental question of the difference between Total Float or Free Float being used in the so called ALAP constraint
I will have a try to your VBA macro
Alexandre
18 years 11 months
Alexandre,
If your only objective is to manipulate the dates to get what you want, then the reverse logic and SF link may be OK; it seems common enough among MSP users of all experience levels.  It is nonetheless a misguided approach in logic driven planning, in my opinion.
Equipment must be delivered before it is installed - full stop.  To discard this requirement and insert the SF link as you suggest is to damage the proper logic flow through the schedule.  As a result, the late dates and Slack of activity 2 (delivery) and its predecessors (e.g. specification, PO, design, production, etc.) are incorrect.  Moreover, the correct scheduling (early dates) of activity 3 (installation) and its successors is not assured in case of a delay of the equipment.
22 years 9 months
Hello Planners,
I would use a Start to Finish link between the activities 3 (Predecessor) and 2 (Successor)
By doing so, the activity 2 would finish at the begining of activity 3, and would not push activity 3 ahead against the milesone
This is the best workaround in MSP, whatever the version you are using .
Alexandre
7 years 1 month
Abel:  // "Wouldn't it be possible, to simply run Activity 2 with a relation type FF to Activity 1? " //
Not and get the desired result - I dont' want Activity 2 to be scheduled to finish with Activity 1, I want its finish to be tied directly to the start of Activity 2 with no float ever.
Logic: (part of the confusion may be a typo in my OP -- fixed here)
1: The finish of Activity 2 as late as possible relative to the start of Activity 3
2:  The start of Activity 3 as early as possible relative to the finish of Activity 1
As Tom has accurately described it, it's a 'just in time' scheduling issue.
Tom's Macro has worked marvelously btw.
JB
15 years
Hi John,
18 years 11 months
Marco,
Thanks for the comment, though I would disagree with your characterization of MSP as a "poor and amateur application."  I would say it's a reasonable scheduling application with some pluses and minuses - primarily aimed at a "poor and amateur", but extremely large, user base.
Rgds, tom
15 years 8 months
Hello Tom and John,
These tips are really important, not only to be a workaround for MS limitations, but also to make visible that many schedules are condemned by MS, because since 1998 they ignore ALAP avtivities.
why insisting in such a poor and amateur appliction, instead of P6, spider project , or even ASTA power project?
Tks.
18 years 11 months
Hi John,
The behavior you seek is that of a Zero-Free-Float constraint, which is not available in MSP.  When used in a forward-scheduled project, the ALAP constraint in MSP is in fact a Zero-Total-Float constraint, which serves no useful purpose as you have found.  Though my memory is a bit fuzzy on the earlier versions (and I skipped from Project '98 to Project 2003), I'm pretty sure MSP has never had a ZFF constraint.  The workaround, at least where Task 2 represents a just-in-time delivery, is to insert a readiness milestone between 1 and 3.  Then make that milestone an FF predecessor of 2.  This keeps the logic flow intact without using the C-word.
Zero-Free-Float constraints are certainly available in other scheduling software - P3 actually called it by that name.  P6 calls it ALAP, which of course causes much confusion for P6 user who stumbles into MSP.  I think Asta Power Project allows entire strings of activities to be similarly delayed within available free float - pretty flexible.
I'm not sure if PP has fixed its image retention problem (uploads like yours were only retained for a couple hours).  If not, I'll move the image below (including the workaround) to an external host. Good luck, tom
[[wysiwyg_imageupload:6094:height=618,width=494]](18Sep'18 - changed image link to external source.)
18 years 11 months
I'm glad you got it worked out.
Sorry I didn't think to mention that macro, which I don't use much.  Maybe I would use it more if it were improved by combining it with a longest-path-type backward logic tracer.  As it is, I've become less reliant on ZFF constraints over the years - in both MSP and OPV - so it's not worth the time to improve the macro.
7 years 1 month
Much appreciated Tom.  Your idea was a great workaround and in many instances worked great in my schedule.  I had a few places where there were predecessors to the Activity 2 you helped me with and those predecessors had the same issue but without the same solution available.
I finally found this blog entry where a user wrote a MP VBA macro that whips through, finds all the instances where you want the ZFF (zero free float) behavior and replicates it programatically (using the ugly 'C' word).  I modified it slightly to meet my needs and it really works great, so until I can afford Primavera, this will have to do
http://www.boyleprojectconsulting.com/TomsBlog/2016/08/31/simple-macro-…
Thanks again.
(LOL -- just realized that it was YOUR blog I just posted.  So DOUBLE thanks and best wishes during the upcoming hurricane headed your way - stay safe.)
JB
7 years 1 month
Thanks SO MUCH Tom.    I'll give that a try in my full schedule and report back.
JB
