Free float as duration automatically
17 years 9 months
Martin, this is how VBA could look like (see next post)
17 years 9 months
Sub ExtendTasksDurationToEliminateFreeSlack()
Dim tsk As Task
Dim amntTasksExtended As Integer
amntTasksExtended = 0
For Each tsk In ActiveProject.Tasks
If tsk.FreeSlack > 0 Then
tsk.Duration = tsk.Duration + tsk.FreeSlack
amntTasksExtended = amntTasksExtended + 1
End If
Next tsk
MsgBox (amntTasksExtended & " tasks have been extended to eliminate free slack")
End Sub
10 years 7 months
Thank you for the answers,
No I only want to use it on follow on activities, which will run from and to dates given by other parameters. This means that I have to change duration on the follow on activities when the other parameters changes, for example an installation date. I want it to have free float zero and not on critical path.
21 years 8 months
If you give them more time they will use it pretending to be busy as there is no hurry, it is the opposite of targeting a tight schedule in the hope you will make it, it is contrary to common sense.
It can be done using formulas, a user defined field to store remaining duration before the tweaking, then add current free float to remaining durations using formulas, recalculate and present the schedule with no free float, before updating restore schedule remaining durations to value before the tweaking, make the update, get new free float values and continue the cycle of deception.
Does Safran Project recommends such a deception strategy?
17 years 9 months
Martin,
I assume, that under " set free float of a activity as the activity's duration" you mean to extend activitie's duration in such a way, that its free float would be 0.
There is no standard way to do it, you would have to write Visual Basic script for it.
But I wonder, why would you need it?
Regards.
Evgeny
