You can link task between projects. It is done with links so remember not to move the projects or the links will break.
Open the projects you would like to create links between. The click on View --> New Window and select the projects to combine. Now the projects are in the same temporary file. Create your links, close and do not save the temporary file and you will see the links between the projects. To view the links click on Project --> Links between projects.
14 years 8 monthsYou can link task between
Best of luck to you.
