Ok, I have received a suitable answer in another forum:
Use the 'Scheduled Duration' field rather than the 'Duration Field'.
Still doesn't explain why 'Duration' field won't calculate correctly, but at least it's an easy workaround.
It may have something to do with the stupid 'manual scheduling' feature that has been introduced in MSP2010.
Btw, this is specifically when using the 'Group By' feature to summarise activities, as opposed to 'indenting' to get summary bars (which I absolutely hate!).
For the record, the 'indenting' method calculates 'Duration' and 'Scheduled Duration' correctly.
Hugh.
21 years 8 months
Member for21 years8 months
Submitted by Rafael Davila on Thu, 2013-02-28 23:30
Definitively Spider Phases roll up as expected, even when working on different shifts on different activities on the same phase.
I wonder how the following is rolled up in MSP. I wonder if shift work is performed on a single activity if MSP would get it right for the single activity because of how different shift and resource calendars determine the work hours on the activity.
24 years 9 months
Member for24 years9 months
Submitted by Vladimir Liberzon on Thu, 2013-02-28 20:46
I think that an information on the work duration on each project phase is useful. Besodes, I don't see the reason why an approach to calculating activity duration shall be different with the approach to calculating phase duration. Phase of detailed schedule may be converted to an activity of less detailed schedule (Levels 4-3-2) and its duration shall not change.
It is easy to apply formula and calculate duration between any dates if necessary but is it real phase duration? The same may be applied to activities that have performance interruptions.
In MS Project resources may be assigned to summary tasks and have hourly cost. Does it mean that phase cost include resource cost at times when it does not work on this phase? Or resource considered busy and is not used on other activities when summary task is not performed?
I would expect the duration of the group to be equal to be the duration of the virtual summary task, pulled above all tasks, included in the group.
In this context, I see, that MSP 2007 calculates it more correctly, then MSP 2010.
The duration of a summary task is calculated by both versions of MSP identically.
By the way, I now noticed, that duration of the phase in Spider is calculated differently, than the duration of the summary task in Microsoft Project, you indeed calculate the time, when there is some work ongoing in this phase . Does it not conflict with the intuitive understanding of the duration of the Phase / summary task? I would personally think that the duration of the phase shall be equivalent to the duration of the hammock, which runs over the same period.
13 years 7 monthsOk, I have received a
21 years 8 monthsDefinitively Spider Phases
24 years 9 monthsEvgeny,I think that an
Evgeny,
17 years 9 monthsVladimir,I would expect the
Vladimir,
Regards.
Evgeny
13 years 7 monthsThanks Evgeny Z, Glad to see
Thanks Evgeny Z,
Glad to see you're able to replicate the problem, so I know it's not just me!
I'll post the same question in those forums you suggested.
Hugh.
24 years 9 monthsEvgeny,usually duration is
Evgeny,
usually duration is measured in work days.
In your example second phase has 10 days duration (another 10 days is idle time).
So you calculated some special duration that shows the number of work days (if you considered calendars) between phase start and finish.
17 years 9 monthsI could reproduce this in MSP
I could reproduce this in MSP 2010, however in MSP 2007 it works how you would expect it to work (see below)
I suggest post your question on MSP spesific sites:
http://answers.microsoft.com/en-us
http://www.msofficeforums.com/
If you get an answer, please post it here as well.
Regards.
Evgeny
