Driving calendars
19 years 10 months
Hi Stuart
As soon as a predecessor task comes out of a none work period the successor task will drop into the first available work day available in its own calendar.
A milestone - having no duration - will drop into a very small gap - even 1 second long.
So make sure you calendars and work patterns are concurrent with no gaps.
Also check what calendars are on the resources.
Mike Testro.
16 years 7 months
Hi Stuart,
I don't have 2007 so not 100% sure, but could this  be because a milestone has zero duration, and hence there is no work being done on the milestone during the non-work day of 30/12/11?
What happens if you make the milestone a 1 day activity with a -1d lag?
