Microsoft Project Member for 17 years 3 months Member for 17 years 3 months Submitted by Samer Zawaydeh on Tue, 2009-02-03 03:05 Permalink RE: Home Cinema Dear Hemanth, At your service anytime. Best, Samer Member for 23 years Member for 23 years Submitted by Hemanth Kumar on Sun, 2009-02-01 23:19 Permalink RE: Home Cinema Thank You I Discussed With My Supplier and Formulated The Plan Thank You For Your Interest & Helpful Mind Member for 17 years 3 months Member for 17 years 3 months Submitted by Samer Zawaydeh on Fri, 2009-01-30 10:12 Permalink RE: Home Cinema Dear Hemanth, I have checked with our local Low Current Supplier, and they informed me that it is totally dependent on the system that you are installing. So I suggest that you discuss the issue with the supplier and formulate a completion plan as per his sequence of work. Best Regards, Samer Member for 23 years Member for 23 years Submitted by Hemanth Kumar on Wed, 2009-01-28 08:20 Permalink RE: Home Cinema Thank you sameer but i was looking for the finer details install projector,lay HDMI cable , install speakers etc Member for 17 years 3 months Member for 17 years 3 months Submitted by Samer Zawaydeh on Tue, 2009-01-27 14:58 Permalink RE: Home Cinema Dear Hemanth, Kindly consider the following: 1) Material submital approval 2) Shop drawings approval 3) Procurement 4) Construction a. 1st fix: After block work and before plastering b. 2nd fix: before complete plastering c. 3rd fix: before complete painting 5) Commissioning: few days before handing over. 6) Programming: after moving in If you need more specific detail, the best source would be the specialist who is going to install the system for you. Best Regards, Samer Log in or register to post comments
17 years 3 monthsRE: Home Cinema
Dear Hemanth,
Best,
Samer
23 yearsRE: Home Cinema
Thank You
Dear Hemanth,
Samer
Thank you sameer
Dear Hemanth,
3) Procurement
4) Construction
Samer
