We fixed part of the issue by trying to change the Print Quality" in the Advanced Options of PDFCreator. It seems to work.
I have another issue with MSP07 when using Group. On the screen it is ok, but when you print (in print preview too) there are colors only for groups names, no more color vertically.
17 years 2 months
Member for17 years2 months
Submitted by Andrew Johnson on Thu, 2009-01-29 20:28
Apart from the obvious - I have found that the more amended views you have the bigger the file - try to reduce all the views, graphics etc and file save as this sometimes reduces the file size. I would also add that printing to pdf from large file sizes has never been a problem for me (upto 150MB)
The problem seems to be with the pdf converter. Try converting Word, Powerpoint files to pdf & check if its the same case. Also the problem can arise if your file size is too big.
The best might be to reinstall the pdf converter.
Kind regards.
20 years 4 months
Member for20 years4 months
Submitted by Charleston-Jos… on Tue, 2009-01-13 05:16
21 years 8 monthsRE: Converting to PDF
Try setting your PDF "Printer" as the "default printer". It works with a similar issue for Primavera Suretrak.
22 years 9 monthsRE: Converting to PDF
hello all,
you should be carefull when using MS Project 2007: the original release is plenty of bugs; be sure to use the Service Pack 1
Alexandre
18 years 8 monthsRE: Converting to PDF
Hello!
I also have this issue with MSP07 and PDFCreator.
17 years 2 monthsRE: Converting to PDF
Thank you all for your advice.
I have tried all but I believe Darren is on the money here.
This option has been used on a collegues pc and it seems to work on there and the 3d is turned off. It does seem to work.
Thanks again
Andrew
17 years 9 monthsRE: Converting to PDF
Hi Andrew,
Theres a known problem when printing to PDF from 2k7. I believe its to do with printer tolerances and a 3D Bars option in MS Project.
If you uncheck the bars and shapes in gantt view in 3D option (Tools > Options > View) then it overcomes this issue.
Not sure if this is the cause of your problem, but it might be worth giving it a shot.
Darren
17 years 4 monthsRE: Converting to PDF
Andrew
Good Luck
Andrew
21 years 6 monthsRE: Converting to PDF
Hi andrew
When printing to PDF - check in the print properties section - What resolution are you printing at
I usulaly print at 300dpi - the higher the dpi, the bigger the file size
Try reducing the resolution (to an acceptable reading level)
Colin
I have tried all of the below!
With no success I think Rubus might be right and the problem lies with the file size.
What would make a relitively small programme have an abnormal large size file excluding the obvious of inserts and company logos?
Andrew
18 yearsRE: Converting to PDF
I agree with Colin.
Kind regards.
20 years 4 monthsRE: Converting to PDF
There is a new kid in the block.
pdf911
But, But?? it is costly.
You can only use it in times of emergency.
Happy Planning and Scheduling
19 years 10 monthsRE: Converting to PDF
Dear all,
PDF 995 is a free software on the web. I use this for all programme print-outs in PDF.
Cherie.
Andrew
Check if you can read them on another machine - if so it may be the reader.
The last time I had a problem with the pdf reader, I uninstalled adobe then re-installed it.
Hope this helps
Colin
Thanks Happy Planning
Have tried all types of PDF creaters
It is my thinking that the problem is with the MSP programme.
The problem has arrived after months of having no problem at all. Seems to work ok sometimes and not others
Having no problem with P6 conversions
andrew
Have you tried using primopdf????
I use primopdf and I did not find any problem.
primopdf is a free download in the internet.
