Thank you to everyone who replied. Following your advice I managed to squeeze the Gannt chart onto one page. It still wanted to print more, but I prevented them by just printing page 1 only.
22 years 9 months
Member for22 years9 months
Submitted by Alexandre Faul… on Tue, 2008-12-02 15:24
this is a well known bug that appeared in MS Project 98 or 2000 and that MS is reluctant to reckognize
as far I as know, there is very little that can be done to correct the situation; sometime, the offending blank page disappears when you check-out the Fit timescale to Page in Preview, Setup, Display ( I am transtlating freely from French), sometime it does not do anything
What you describe is fairly common but there are a number of probable causes. Hopefully one of these suggestions will give you a solution.
Change the date range
(File > Print) in the Timescale options either select the All radio button or select the Dates radio button and change the Finish date so that it’s after the end date of the project.
Change the Gantt Chart timescale to fit on A1 before you print
(Format > Timescale) adjust the timescale on whatever Tier tabs you use (i.e. if you use days change to weeks, if you use weeks change to months). Then use the print preview to see if it fits on one page (File > Print Preview).
Only print the first page
(File > Print) in the Print Range options select the Page(s) radio button and then only choose the print range From: 1 To: 1. this should only print the first page.
You can also use Page Setup if none of the above fixes your problem.
21 years 9 monthsRE: Annoying print settings
22 years 9 monthsRE: Annoying print settings
Hello all,
just be patient, its only MS Project...
Alexandre
17 years 9 monthsRE: Annoying print settings
Hi Terry,
Darren
17 years 2 monthsRE: Annoying print settings
Have you tried reducing the Size % in the timescale data when you right click the dates at the top of the Gantt?
You can fit to one page also (page setup) and or opt to only print the timescales that you need when you press file print (bottom corner)
