Microsoft Project Member for 17 years 7 months Member for 17 years 7 months Submitted by arun kumar on Tue, 2008-09-30 01:07 Permalink RE: Print Preview in MSP Thanks all Actually WMF image was inserted in Header.. I deleted that now its working.. Arun Member for 19 years 11 months Member for 19 years 11 months Submitted by Trevor Rabey on Mon, 2008-09-29 19:36 Permalink RE: Print Preview in MSP Install a printer driver for a large format printer if you dont already have one, say HP1050C. You dont need the actual printer, just the driver. Or print to PDF. Then you can print to ISO A0 sheet which is big enough for anything. Then you will see how many columns you are trying to print. Also, in the Gantt Chart View zoom out. Member for 22 years 9 months Member for 22 years 9 months Submitted by Alexandre Faul… on Mon, 2008-09-29 14:51 Permalink RE: Print Preview in MSP Arun, Can you install another printer driver on your PC and try it? Or try to print another project, try with a dummy 2 task projects Your problem could arise from some error in your project file Hope it helps Alexandre Member for 17 years 7 months Member for 17 years 7 months Submitted by arun kumar on Mon, 2008-09-29 06:52 Permalink RE: Print Preview in MSP Dear Trevor I tried but not working. Still the same story. Arun Member for 19 years 11 months Member for 19 years 11 months Submitted by Trevor Rabey on Mon, 2008-09-29 06:22 Permalink RE: Print Preview in MSP First, make sure you have selected the correct printer if you have various printers to choose from. Use File, Print then select the printer then click on preview. Try using File, Page Setup before you try to File, Print Preview. Thats where you can fix it. Check the View tab and make sure you have not told MSP to print too many columns. Reduce the margins to small but not too small (1 cm). Then Print Preview. etc etc I think you know the rest. Log in or register to post comments
17 years 7 monthsRE: Print Preview in MSP
Thanks all
Arun
19 years 11 monthsRE: Print Preview in MSP
Or print to PDF.
22 years 9 monthsRE: Print Preview in MSP
Arun,
Hope it helps
Alexandre
Dear Trevor
Arun
Then Print Preview.
