Open Additional file in New Window
17 years 7 months
Darren,
I only got problem with this file only. But previously I have also met this kind of problem.
I try to rename this file & give it a simple short name and it works. I think it could be due to the fact that I could be using a long name (about 85 characters, with brackets & commas in between) to identify the file.
I will also try out the methods you method if I meet this kind of problem again.
Thanks for you help
Wan
17 years 9 months
Hi Wan,
Do you have this problem with all .mpp files or just this one?
Have you tried re-naming the problem file and trying again?
As an alternative, have you tried creating a copy of the original file and then use the Window > Arrange All function to compare the two files instead?
Darren
