OUTLINE CODING Question
22 years 9 months
Pinan T. and all others,
I confirm Paul Harris’s post: it is definetely NOT possible to hide the 1st part of the outline code or of the group name; you cannot display: for instance if you group tasks on priority level, you cannot hide "priority:"
Alexandre
23 years
Nothing Works
Go Back to MSP 2003
2007 is crap
several bugs
cant use it with P6 to save the project in
who want 3D bars
F**K OFF
16 years 8 months
This is an oldish thread, I was wondering if there have been any developments on this issue? Service Pack perhaps (he says hopefully)?
I’ve just been "upgraded" from 2003 to 2007 but after two days of trying to make it work I’m now thinking about going back. Previously my hierarchical outline coding worked beautifully, now code Values are displayed instead of Descriptions, and the groupings don’t work at all.
I’ve replicated my hierarchical structure with individual codes which has sorted out the grouping issue, but it makes little difference because the descriptions still can’t be seen!
Next step is to make the "Value" the "Description".
Long time Primavera user now suffering with Project. Ah, the good old days....
23 years
Yes
You Cant In MSP 2007
But Yes Sure In MSP 2003
and several other bugs in 2007
Hemant
24 years 6 months
My understanding is you can not.
Paul E Harris
Planning and Scheduling Training Manual & Book Publishers, Consulting and Training
www.eh.com.au
21 years 6 months
Sorry Pinan
But since I haven’t got 2007 I can’t check.
Hopefully someone else out there can help who has 2007
Good luck
Colin
18 years 3 months
thanks, but im using msp 07 and outline code name appears to the left of the grouped outline with a separator :, values appears and not description.. or am i missing an option tick here?
21 years 6 months
Sorry Pinan
I mis-understood and I typed without checking.
I should of also clarified that I am using MSP 2003.
Testing the situation, when I use the outline code - this does not give the name at the start (it only does that if I use Text1)
Try below -
Tools / customise / fields
Select ouline code 1
Click edit lookup table
Then if I type 1 etc in the outline code and to the right the desciption :-
1 Engineering
2 RCC Works
3 MEP works
Does this give what you want
An alternative is to name the value "1) Engineering" etc
Colin
18 years 3 months
thanx but what i mean is to hide that part.. it keeps on showing like that, say i rename the O code 1 as PHASE, then values include ENGINEERING,RCC WORKS, etc. then after grouping, it will show PHASE:ENGINEERING, PHASE:RCC WORKS.. what i want is to hide "PHASE:".. and i notice also that it will be in alphabetical order sequence, how can i patterned it as defined, say ENGINEERING, then RCC WORKS, then MEP Works, etc.
21 years 6 months
Hi Pinan
Tools/customise/fields
select custom outline codes
select outline code 1
Click Rename
Enter name of your choice
Colin
(let me know if this is helpful)
