"Claimdigger" for MS Project
19 years 3 months
yes it is built in to project from 2003 onwards
compare project tool bar allows you to choose two project files and then it compares every field for changes, i use this regulary!
Dave
19 years 3 months
u can copare the track the changes made in the predecessor / successors..
Exprot / copy the files with predecessor/successor columns in to Excel and make a comparison check in excel using functions....
Venkat
22 years 9 months
Not exactly,
it is possible to display the Predecessor and Successor columns and compare the differnet versions
its is not as easy as the P3 add-on
Alexandre
22 years 3 months
Alexandre,
is it possible to get a list of changed predecessors and successors?
22 years 9 months
I agree with you, you will find many things much better than any MS piece of a software
22 years 3 months
Thanks, Alexandre.
I am trying to understand MS Project and so far I am not impresed.
22 years 9 months
NC,
MS Project 2003 and 2007 Pro have a toolbar to compare differences between versions of the same project saved in several mpp files. I don’t know if MS Project Standard has the same feature.
Alexandre
