change working time to 00:00 - 00:00! 23:59 is Primavera P3, NOT MS Project; in MS Project, that makes every single day 1 minute shorter, and to work 24 hours you v will need ONE day PLUS One minute
Alexandre
19 years 5 months
Member for19 years5 months
Submitted by Mark Chapman on Wed, 2007-04-18 12:28
I just created a one line activity with a 28 day duration using a 24 hour calendar. You then need to change working time to 00:00-23:59. The EF date will be 00:28. Is this what you wanted? Or did you want something else?
In the end I merged plans using the formula but manually rounding down when there was a percentage.
However, I see me having this problem regularly. So would like to know how to convert a duration into an integer and back again as some of the functions like round can only be used on integers.
mark
22 years 9 months
Member for22 years9 months
Submitted by Alexandre Faul… on Wed, 2007-04-18 10:44
OK I sorted this out as I am used to P3 and I had put the finish time as 23:59 and initially (1st problem) I had changing the working time just for 1 day.
19 years 5 months
Submitted by Mark Chapman on Tue, 2007-04-17 10:33
Thanks Alexandre for your help. Its worth keep the notes here so everyone else can use as reference.
The help above was excellent but this had led to more questions:
1. I see my formula has some inconsistancies, ie anything thats not a week long. So rounding down will work for the majority of the time but will "rnd" work? Or is there a formula for "remainder" then I could work out exact figure.
2. The duration is calculated in days which is fine for the imported plan but I dont want the shutdwon plan converted to days too. I can change the duration unit to either hours or days but I want to leave those in days as days and those in hours as hours.
3. In the old 5 day week plam the activities started at 8am and finished at 5pm but in the new plan the activties start and finsh at 00:00 despite 23:59 being set in options/calendar???
Look:
24 Hours 8 days 03 Apr 00:00 11 Apr 00:00
24 Hours 0 days 11 Apr 00:00 11 Apr 00:00
24 Hours 28 days 11 Apr 00:00 09 May 00:01
24 Hours 7 days 09 May 00:01 16 May 00:01
4. Why 00:01???
Mark
22 years 9 months
Submitted by Alexandre Faul… on Tue, 2007-04-17 07:51
Youre right, its best to insert a project with no actuals; Iif means "Immediate If", it is the same as the regular "If, Then, Else" in a spreadsheet app;
go to Tools, Customize, Fields, then select a duration field and create the formula in there; then in the gantt chart spreadshhet columns, replace the usual Duration field with the field that contains the formula.
Alexandre
19 years 5 months
Submitted by Mark Chapman on Tue, 2007-04-17 07:20
I am making slow progress. I am importing my 5 day week plan into the 24 hour shutdown plan. I think I maybe best to remove actuals first and then insert this project.
These activities are using the default calendar, "none" and I have modified Paul Harriss formula to this:
When I copy the 5 day plan into the 24 hour plan, it decreases my durations by a third. Which isnt a surprise but I am not sure the best way forward. The fact that its a duration and not effort is the problem. I want to keep my 5 day duration as a weeks work. So in the 24 hour plan this will convert to 98 hours or 7 days and not 1.67! I would need to multiply by 21/5 but I am not sure where or how to do this.
Alexandre, I see when I insert the project it continues to link to the original file but I dont this. I will try unclicking the "link to project" to resolve this.
22 years 9 months
Submitted by Alexandre Faul… on Tue, 2007-04-17 04:31
Better use "Insert, Project" than Copy and Paste to merge one project into another, you wont lose any data that way; be carefull to summarize the target project at the minimum and place the cursor where you want the inserted project to take place, to avoid the inserted project to become a subsidiray task in the target project.
19 years 5 monthsRE: Merging MSP Plans
I totally agree and I had worked this out 2 days ago. Cest le vie!
22 years 9 monthsRE: Merging MSP Plans
Mark,
Alexandre
Hi Alexandre,
mark
Mark,
in MPS make sure your 24 hour/day calendar is open 00:00 to 00:00; its not the same as P3!
I dont know why you have these strange finish date/time; can you pls send an example of this to afaulxbriole@wanadoo.fr
Alexandre
No constraints on any of these activities!
I have been tinkering further and this now happens:
24 Hours 7 days 03 Apr 00:00 10 Apr 00:07
24 Hours 28 days 03 Apr 00:00 01 May 00:28
So whatever my duration, say x, then there will be x minutes!
19 years 1 monthRE: Merging MSP Plans
that means theres a lag of one (1) minute FS - with one minute lag
Look:
4. Why 00:01???
Mark
Mark,
Alexandre
Hi Alexandre,
=IIf([Task Calendar]="None",[Duration]*21/5,[Duration])
However I am not sure how to set this calculation into a number field first and then the duration field.
Also what is the "I" before the "IF"?
Mark,
MS Project only has ONE setup for how many hours in one day; thats why you have this problem.
Paul Harris has designed a formula to get correct task duration whenever the task calendar is not the regular one, you will find it at
http://www.planningplanet.com/forum/forum_post.asp?fid=1&Cat=4&Top=28177
Hope it helps,
Alexandre
deliberate mistake - 168 hours per week!
Thanks Alexandre & Quiamco,
Mark and Quiamco,
Alexandre
