Macros in MS Project
20 years 3 months
hello Manulal
of course you can also use these MSP-macros from an Excel-Task. I.e. that you can transfer data very easily and use the graphical possibilities of excel to show the information of MSP. Or even better - you can connect to AutoCAD or P3 using these macros.
20 years
Hi Zhang,
Thank you. I have already started learning more about macros in MSP.
Manu.
20 years 6 months
They are almost the same. The difference is the objects(events,method...). You can learn these from the HELP file,also recording & studying.
It’s better to go through all the objects in MSP.
20 years
Will the VB macros we use in excel work in MSP as well.
I learnt most of the macros coding in excel by recording a macro and then analysing the code. But this method does not seem to be easy in MSP.
Manu.
20 years 3 months
Hello Zhang
thanks for the answer, it is realy a nice idea. I would even be more happy if you could copy some of the macro-text in your answer. As I said I work a lot with macros too and I noticed in the past, that people work in very diffent ways with macros. Those different approaches are the things that interrest me, because from that I can learn a lot more than from the examples of Microsoft
Regards Hannes
20 years 6 months
just use taskdependency object to check each pred of current selected task, and use the link type & lag to calculate the start date of the current selected task, if the date equals to the start date of the current selected task, then consider it as driving pred.
20 years 3 months
Hi Zhang,
this sounds very interesting. Is it possible to put this macro in this forum (just as text). I like writing makros as well and its always good to learn from ideas of other persons.
Hannes
20 years 6 months
Yes, you can use macro to imporve MSP.
I’ve write a macro to make a predecessor form the same as P3, using * to indicate driving preds.
22 years 5 months
I believe it is best use in excel...
24 years 9 months
Unfortunately you will not use macros for resource leveling.
