MS Project Server Multi-editing?
20 years 2 months
Primavera Systems will support multi-editing on the same project, the only limation is on the record level; which actually means that it will allow changes on one record by the user that first accesed it. It will not allow 2 users access the same record(acticity) at the same time.
I hope this helps you!!!!!
22 years 7 months
Answering to the last part of your question, Primavera, and some other packages, supports multiuser editing, with the same limitatons of a concurrent database. This means that if you have two users updating the same data at the same time, only one change will be made to the central database in order to keep data integrity.
Hope this is of help.
21 years 4 months
Hi there,
No, you can’t actually have multi-users accessing the same project with Project Server 2003.
22 years 9 months
Are you working with MSP Server 2002 or 2003?
Do you want to multi-edit the project schedule by using MSP Server via PWA or MSProject from the planner windows workstation?
Alexandre
