If you have purchased Project Server 2003 and Project professional 2003, you have the enterprise capability (assuming you have followed the installation process correctly.
If you have installed correctly, the easiest way to see if you are connected to the server is go to Tools and look for Build Team from enterprise. As the previous posting identified, if it is greyed out, you are not connected.
Usually, again assuming you have installed correctly and you have the enterprise version of Project, it is the Project Professional setup that is faulty.
First, check Collaborate/Collaberate Options. The Project Server URL must be defined correctly. Press the Test Connection button to validate.
Next, go to Tools/Enterprise Options/Project Server Accounts. The project server entry must be set as the default. After setting this, close down MS Project and reopen. You will get a message asking if you trust the server connection. After accepting the Trust This, you should be connected and can then access and save projects to the server.
22 years 11 months
Member for22 years11 months
Submitted by Blanche Chan on Tue, 2004-05-11 23:16
When you first bring an external project, or define a new project, the plan is "local" (i.e. not an enterprise project). When you try to publish, you will receive an error message. In MS Project Professional, go to Tools/Enterprise Options/Import Project to Enterprise.
This will transfer your plan to the enterprise (assuming you have connected to Project Server) ..... RickD
22 years 11 months
Submitted by Blanche Chan on Mon, 2004-05-03 22:52
Firstly "Enterprise" is an optional module that you need to buy on top of project server. Secondly what you meant by "upload the project to the proejct server"? e.g. Publishing the project?
16 years 9 monthsRE: How to make a project become
22 years 11 monthsRE: How to make a project become
You will get the Enterprise Option only when you bought this option or it would have been grayed out
