This question is for PP Admin or anyone that can advice accordinly.
Anytime i try to access planning planet website, i get an error message at the first instance, then when i referesh, it opens. Pls see the error message below:
Microsoft OLE DB Provider for ODBC Drivers error 80040e14
[MySQL][ODBC 3.51 Driver][mysqld-5.0.18-nt]You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near at line 1
C:\_PLANNING_PLANNET_FILES\WEB\V.1.2.0.5\FORUM\../includes/inc_functions.asp, line 651
19 years
Member for19 years1 month
Submitted by mimoune djouallah on Fri, 2007-06-01 17:59
Congratulation!!! for being a Project Manager...well this sounds like your resposibility is bigger than your previous activity.... May the Best In everything to you...Good Luck In Everything you do...
Jerry
18 years 6 months
Member for18 years6 months
Submitted by Ashraf Jahangeer on Mon, 2007-05-28 08:06
Congratulations on moving to Project Managers post? I have been reading your post since the time I joined PP. Wishing you all the best and looking forward for interesting posts from you.
By the way as an intiator you have the rights to delete your posts and no need to ask PP admin for this service.
Ashraf
20 years 4 months
Member for20 years4 months
Submitted by Charleston-Jos… on Mon, 2007-05-28 07:38
Im still in UAE. Im going to project manager positioin. Planning, for me, will become a tool to achieve project goals.
I will take all the advice.
PP Admin, Please moderate (delete) my previous post.
I would prefer to focus on PP Admin question and to behave like a good boy here in PP world. I hope my new position will enriched PP a new look regarding project management in general and planning in particular.
To my peers in PP, please forgive my previous way of sharing ideas.
Charlie
20 years 3 months
Member for20 years3 months
Submitted by Jerry Alivio on Mon, 2007-05-28 00:54
Hello People, can we just be professional, writing those foul words is not good in this website. PP is suppose to be Sharing, giving good thoughts and ideas about Planning, right?
On the subject of why most of the adverts are for jobs in the United Kingdom is simply that recruitment is (we understand) big business in the UK and as such, there are some major players who actively recruit - and hence take advantage of PPs diverse and rich membership.
We tend to think that Andrew is quite correct. The way to get more diverse and worldwide jobs on PP is for us all to tell the companies and recruiters in our respective countries about PP. By doing this, we will all benefit in knowing about, and finding that next job.
We are also thinking about a way for us planners to fill the vacancies which arise in our respective companies. Perhaps we should, or could, challenge our bosses in that we can find the most suitable planners to work alongside us rather than having to use a head hunter or recruiter. This could be the beginning of a new Global Recruiter!!!!
Something to think about!!!
Keep on planning...
24 years 4 months
Member for24 years5 months
Submitted by Andrew Pearce on Sat, 2007-05-26 04:55
Guys are we missing the point of the original posting?
Why no worldwide job posts?
I believe the answer is that a lot of UK revruitment companies are using PP, most of the "rest of the world" vacanies are also posted by UK compaines or overseas offices of UK companies.
If you want more world wide vacancies posted then inform your local recruitment compies about PP.
21 years 5 months
Member for21 years5 months
Submitted by Chris Oggham on Fri, 2007-05-25 03:52
I totally agree with you; Charlies remarks were offensive, ill-informed and unnecessary. However, I dont believe that there is any point in attempting to get him to acknowledge his error as I dont believe he thinks has made one.
From what I have seen Charlie believes Charlie is always right and his justification of his position ranges from the mildly eccentric to the downright bizarre. If you attempt to press him too closely, though, he will sidetrack the discussion with irrelevances or childish obstinancy.
Probably the best thing to do would be to waste no further time on this matter. After all, the people in Planning Planet are quite capable of recognising ignorance and intolerance when they see it. Im also sure they are quite capable of deciding for themselves how much notice to take of someone with such opinions.
Chris Oggham
23 years 7 months
Member for23 years7 months
Submitted by David Bordoli on Thu, 2007-05-24 09:40
Drawing lines or burying heads is no real solution to the ignorant and offensive remarks that Charlie specialises in. I’d be happier if he acknowledges how odious some of the things he churns out are.
22 years 4 months
Member for22 years4 months
Submitted by Shahzad Munawar on Thu, 2007-05-24 09:36
Don’t need to go in further detail. This issue should be closed now rather than to discuss more as it relates to PM not a part of forum discussion. In short UK and all other countries have qual opportunities for all, subject to prove yourself.
18 years 9 months
Member for18 years9 months
Submitted by VENKAT RAMANA on Thu, 2007-05-24 09:05
I take extreme offence at your posting, which yet again is borne from your ignorance.
The UK is the most racially diverse and multicultural place in the world and London is even more so. We have laws that prevent us from discrimination on race, gender sexual orientation and religious grounds. Hey, if we are so bad why the heck would you want to come and work here (as you have said in other posts).
Before you cast aspersions Charlie I suggest you take a good long look in the mirror and, as has been suggested before, put your brain in action before you speak. Maybe the apparent chips on your shoulders and your own discriminatory views are colouring your judgement.
David
21 years 5 months
Submitted by Chris Oggham on Thu, 2007-05-24 03:59
Posting your question is fine, but you may get an answer more quickly if you send PP Admin a private message. To help you do this, please follow the steps below:
1. Click on the Members link on the navigation menu, this will take you to the search page;
2. Type PP Admin in the Search Text box and select All word(s) from the drop-down menu next to it;
3. Click on the Search button and the results for PP Admin will be displayed;
4. Click on the envelope icon and you will be able to send a private message to PP Admin detailing your question and concerns;
18 years 9 monthsRE: This question is for the PP’s Admin..
19 yearsRE: This question is for the PP’s Admin..
Charlie, congratulation, if you need a young planner who speaks french and arabic i am here.
friendly
19 years 1 monthRE: This question is for the PP’s Admin..
Charlie,
do you need an assistant?
good luck!
20 years 4 monthsRE: This question is for the PP’s Admin..
Hi Vladimir,
I thank you.
Charlie
24 years 9 monthsRE: This question is for the PP’s Admin..
Hi Charlie!
My congratulations!
I am sure that you will get all possible support on this site.
Vladimir
Hello Jerry and Ashraf,
I thank you.
How to delete my post # 14.
Charlie
20 years 3 monthsRE: This question is for the PP’s Admin..
Hello Charlie,
Jerry
18 years 6 monthsRE: This question is for the PP’s Admin..
Hi Charlie,
Ashraf
Hi jerry,
Charlie
Hello Charlie!
What is this all about??? Soul Searching...Relax lang.. long time no see!! how are you now a days...its nice to be back in PP.
Are you still in UAE?
Cheers!!!
16 years 9 monthsRE: This question is for the PP’s Admin..
Hi All,
Keep on planning...
24 years 4 monthsRE: This question is for the PP’s Admin..
21 years 5 monthsRE: This question is for the PP’s Admin..
David,
Chris Oggham
23 years 7 monthsRE: This question is for the PP’s Admin..
22 years 4 monthsRE: This question is for the PP’s Admin..
Excuse me Planners,
The question i posted is nothing about the social life at UK and the discrimination.
Please read my question carefully,my question was clear.
I request you all,please dont create any sort of discrimination in the part of career.
VENKAT RAMANA
Charleston
David
Hi Vencat,
Chris Oggham
