Bernard, we checked the script and it appears that you had put your web address inside some quotation / speech marks. An html quirk that works in some instances and creates problems in others. We removed them it is looks and works great. Hope it’s as expected.
MK, we will look at your other suggestion. Thanks. In future it would be great if a new topic was started each time you want to approach another subject.
Propose to move both "Primary Industry" and "Member since ..." from left column to right column, ject next to the profile button. So information of profile grouped together and reduce the scroll down movement.
22 years 11 months
Member for22 years11 months
Submitted by Bernard Ertl on Tue, 2003-11-18 09:52
The display of the company name in the Member Network viewing tool (when searching for some text and viewing the table of results) needs a slight adjustment. Search for "Bernard" and you will see what I mean.
Company Name Hyperlink - If you log in and go over to the Member Page you will see the usual "Review and Ammend your Personal DATA-FILE" hyperlink.
This will now allow you to enter or ammend your "company name" in such a way that it will be presented on the site as an internet hyperlink, rather than as just text. Other members can then click on your company name and be taken straight to your preferred site.
Hope this improves things for you. Thanks.
22 years 11 months
Submitted by Bernard Ertl on Mon, 2003-11-17 12:05
Would it be too much trouble to allow/offer hyperlinks from the company name on member pages (visible through the profile button) to the companys web site?
16 years 9 monthsRE: Network Tool and Forum Posts
Hi there,
Reqd = < a href=http://www.google.com>Comapny Name
Your = < a href="http://www.google.com">Company Name
(omit space shown between initial "<" and "a")
Thanks for your continued support.
23 years 8 monthsRE: Network Tool and Forum Posts
One more suggestion: -
22 years 11 monthsRE: Network Tool and Forum Posts
Thanks again. That was fast!
Bernard Ertl
InterPlan Systems Inc. - Project Management Software, Project Planning Software
Hi PPers,
... and the requests just keep coming... :)
Bernard Ertl
Thanks! I like it.
Bernard Ertl
We have added a "Primary Industry" flag in the left column.
The data entry field for adding your primary industry is located via an "Edit your Personal Data-File" link on the Members Page.
Trust this helps improve things.
Hi there,
This Profile button is great, it readily shows me the expertise of a member - something I was not aware of before.
Bernard, we have added your request for "Primary Industry" to the to-do-list.
OK. The Del button did not work the last time I tried it months ago. It worked this last time. This is a non-issue.
Bernard Ertl
To remove a name from network, click on the name, then either button ADD or DEL appear, press DEl will remove the name from your network
