Apportionment of Delay
21 years 8 months
Mike,
Remember "Pirates of the Caribbean", it is not Tequila, it is Rum.
By the way do you know who are the owners of Dewar's Distillery [belive is a flavored distilled water]? It is Bacardi, five minutes from home.
19 years 10 months
Hi Rafael
Lovely contribution.
Has the weekend tequila worn off yet?
19 years 10 months
Hi John
It depends on the circumstances and also whether you are working in the USA.
Regarding the UK:
For when work is in progress the only method available is the Impacted as Planned which is required under NEC contracts but also useful for other forms.
If you are a sub-contractor relying on available work fronts from other sub-contractors then As Planned v As Built works very well but may also have to be combined with Impacted as Planned.
For retrospective Forensic Planning then Time Impact analysis is the Gold Standard provided the As Built data is good enough.
I avoid the As Built but For (Collapsed As Built) because it is very easily destroyed by challenging the As Built logic driving the critical path.
Just lately I have been using the Super Summary method to good effect because it is so simple that even a Judge can understand it.
21 years 8 months
Avoid solving Delay issues on the run, leave it to the end. Who cares, the latter the better. Will save you money.
At the end 100% of the Delay issue will be solved in your favor, it does not matter on which side you are, you can count 100% on this.
15 years 7 months
Hi Mike
Thanks for your response, so basically once the project is complete the total delay can be apportioned as the this will obviously equal total monthly delays minus mitigation.
Out of interest what would your preffered method of analysis be?
John
19 years 10 months
Hi John
Windows analysis does not assist in apportioning concurrent delay - you have to look at the whole picture before you can apply concurrency rules.
(This is one of the reasons why I never use the method.)
With the complete picture you will then be able see if the mitigation exercise was indeed effective.
