I agree with you but I'd even go one better I think.
Even if the contract had been signed AND the work was underway, the variation represents such a fundamental change in the method and sequence of work (even though the scope remains the same) that the original intention is lost and a new price/timescale should be agreed.
But if it is only a letter of intent, its a no-brainer I agree.
Its important to recognise that a variation is not just limited to the scope of work. In this case the scope of work remains the same . i.e dredge to -8m.
There is a credit for the removal of demobilsation and remobilisation between the 2 phases. But there is time and cost consdierations of doing the dredging deeper in one operation.
However in this case the variation is so fundamental that Mike is right when he says that the only way forward is to renegotiate the contract - both time and money
Ken
14 years 7 months
Member for14 years7 months
Submitted by Project Manager 67 on Sun, 2011-11-27 22:08
The customer has instructed a change to be made in the agreed scope of work. This is a clear variation and as such this should be formally notified to the customer, typically by letter. This change might impact cost and\or time and introduce new risks (technical, commercial and occupational safety risks) to the project. The first thing to do is to take stock, assess the change to establish the full schedule and costs impact and then importantly revisit any task risk assessments to establish if they are still valid. All the impacts should then be communicated to the customer.
Can you kindly explain further as to why the scope of works will be presumed as differrent from what was agreed. As I uderstand it, works under A first then B second is no different to A directly going to B. Nothing is ommited. However the variable that might change with this fast tract approach is time, which should be looked up.
As I understand it, the scenario you mentioned does'nt qualify as a variation order simply because you still have the same scope of works. However, you still need to check if the change in methodology will affect your timely delivery. If yes,then only time can be variated/extended from your contract.
17 years 3 monthsHi MikeI agree with you but
Hi Mike
19 years 10 monthsHi Ken Nice to hear from you
Hi Ken
Nice to hear from you again.
The main basis of my opinion is that the contractor is working from an ill defined letter of intent - so no contract is extant.
But it would still run even if there was a fully signed up contract but no work had started.
Mike Testro.
17 years 3 monthsIts important to recognise
Ken
14 years 7 monthsThe customer has instructed a
14 years 5 monthsHi ; Option 1: Scope of Work
Hi ;
Option 1: Scope of Work has changed to the Phase 1 work, there is variation claim
1) You may need to mobilise additional equipment to dredge at deeper location, definitely there is cost involved.
2) Material at different level vary, disposal cost also may vary , definitely cost involved
3) Rate of excavation too vary at deeper place , time involved
4) You do not required double mobilisation, cost saving
Senthuran
19 years 10 monthsHi Bill The fundamental
Hi Bill
The fundamental difference is that stage 1 was dredging o > -4 m which has a price time and stage 2 was from -4 > -8 which has another price and time
Now they are being asked to dredge from 0 > -8 in one hit and there is no price or time for that operation.
So a new price and time has to be agreed.
18 years 1 monthHi Mike, Can you kindly
Hi Mike,
Bill
19 years 10 monthsHi Ayman It seems that the
Hi Ayman
It seems that the employer has omitted phase 1 and extended phase 2.
As usual it all depends on what it says in the contract but to my way of thinking you now have a totally different scope of works.
My advice is to immediately negotiate the new contract rates and time before proceding any further
18 years 1 monthAs I understand it, the
Bill
