Whilst Mike thought that Keith Pickavance waffled, having also attended I have to disagree.
The work the CIOB have produced will be published later his year as "A Guide to Good Practice in the Management of Time in Complex Projects". Its a very comprehensive piece of work, and is the first step toward getting planners and schedulers recognised qualifications.
The comments on its content from leading authorities such as Murray Woolf are very good, and as such when published I encourage you all to at least take the time to read it.
Toby
17 years 3 months
Member for17 years3 months
Submitted by Samer Zawaydeh on Fri, 2010-03-05 13:13
And the cause of problems shall be repeated and repeated - one day people shall take notice of them and act on them to prevent problems:
In 1939 Edward Rimmer wrote a paper called "The Conditions of Engineering Contracts", ICE Journal Vol 11, p3 (1939) - outlining the problems with construction projects and suggesting ideas for the way forward - partly from which the ICE Standard Form Contract 1st Edition was born in 1945.
If you can find a copy of the paper it’s worth a read - just to confirm that many of the problems encountered today were there in 1939 and haven’t changed much!!!!!!!!
Interesting contracts from a programming and planning angle, trying to ovecome some of the problems, are the new(ish) Irish Government public works contracts:
What is states is the obvious. That is good to know. It is a benchmark.
In the sea of information, they are stating the problems and what can be done about it. Its a good picture/guide for things to avoid and things that might happen.
Agree, experienced people might find it business as usual.
16 years 11 monthsRE: Article: Time for Change
Hi samer it is really worth going through it >
Shahul
17 years 3 monthsRE: Article: Time for Change
Dear Ravi,
I think it is good to read. That is why I posted it. I am glad that you liked it.
With kind regards,
Samer
18 years 5 monthsRE: Article: Time for Change
Thanks Samer for sharing tat wonderful article.
18 years 3 monthsRE: Article: Time for Change
Dear All
Toby
Thank you Andrew,
A lot of people will benefit from this information.
With kind regards,
Samer
16 yearsRE: Article: Time for Change
Hello Andrew,
Thank you for the link.
Nice to see you round here as well :D
Roland
20 years 10 monthsRE: Article: Time for Change
http://www.constructionprocurement.gov.ie/P1Contracts.aspx
Download contract PW-CF4 and have a look at, (they are all similar):
Progress Reports Cl 4. 9 & 4.10
Time & Completion Cl 9
Notices Cl 10
Lets not forget one important note,
Most creatures on this planet seem to require repetition until a certain obvious idea really sticks in..
So yes it might not be that bad after all.
Plus champagne is not that bad, is it now? :)
Roland
Dear Mike,
With kind regards,
Samer
19 years 10 monthsRE: Article: Time for Change
Hi Samer
I attended the seminar where this paper was presented - the champagne and canapes were above average.
Otherwise I found nothing new and Keith Pickavance just waffled.
I recall that I finally binned the handouts last week.
Mike Testro.
Thank you Samer!!
Much appreciated.
Roland
