Gary your suggestion seems reasonable, though I am not sure they will be as to accept it.
Your statement "But it is unreasonable to expect a contractor to change their planning system (which may be lniked to timesheets, accounting, inventory, etc software) at the whim of the client." goes right to the target bulls eye.
Thanks, seems like a good bullet, a silver bullet.
Finally I am getting a few good arguments in our favor, I was starting to feel like a roach on a chikens party.
R. Davila
16 years 7 months
Member for16 years7 months
Submitted by Gary Whitehead on Fri, 2009-05-15 10:10
I can understand why the client (government or not) would not want to have to convert the project from one format to another, as this can lead to conversino errors which could make assessing claims / LDs very problematic (which version is the real baseline?)
There may also be very valid reasons why they cannot purhcase a copy of the software you want to use, for example they may have a preferred supplier system or a ban on installing non-standard software.
Would another option be to perhaps include within the tender bid a laptop loaded with your preferred software for the client to use?
21 years 8 months
Member for21 years8 months
Submitted by Rafael Davila on Wed, 2009-05-13 15:13
I agree with the U.A.E. best case scenario - the float belongs to the contractor.
Then under the above premise the impact should be analyzed taking into consideration resources availability and not merely the simplistic approach of assuming that it belongs to whoever reaches first.
Seems like the European norm is correct, we are somewhat behind, even when some courts have ruled as per the European norm some specifiers insist otherwise.
Samer
I believe they will end using P6, what I cannot accept would be to require us Contractors to use P6 or Primavera Contractor. From P6 they should be able to read P3 files; P3 files form SureTrak, MS Project in many variations plus P6, Primavera Contractor, P3e, P4 and P5. In a couple of years they will be close to P35 then I believe they will skip some numbers as to avoid confusion with WWII airplane names.
It seems like a spec taken by the Architect from a drawer without cleaning the dirt. The problem is when you get a stubborn inspector and an Architect who knows nothing about CPM Scheduling, believe me we have seen a few. Seems like this issue is better to be resolved before bid opening as Andrew suggests.
In their capital program schedule? A single bar should do it, is the Contractor’s Schedule, not theirs. Who in top management is to analyze millions of activities? This is not a State Utility doing hundreds of jobs with their own forces.
Sory Microsoft, Micro Planner, Open Plan, Spider Project, you are out, it is not your money, you are not paying your taxes, only Primavera is. Do you?
Thank you all, you are helping us to sharpen our request if we decide to raise the issue before times runs out to do so, it will be of great help.
17 years 3 months
Member for17 years3 months
Submitted by Samer Zawaydeh on Wed, 2009-05-13 15:07
You can easily prepare a comparison sheet between the two softwares (P3 and the Contractors choice).
You can also ask the Client for the information that they need to extract from the Schedule periodically. Most probably they will use it in their capital program schedule. You may offer to provide this information and in the format that they want.
I do not use these techniques in my schedules. I am working in U.A.E. and here the float is either owned by the contractor or in the worst case scenario; based on who reaches the activity first; owns its float.
Sherif
21 years 8 months
Submitted by Rafael Davila on Wed, 2009-05-13 11:22
We will not make a fuss out of it, if we decide to ask the question, as we are still on time, it will be in a professional and respectful language, not as informal as we are discussing the issue here. Yes your advice is welcome.
Remember P3 is no longer sold nor supported by Primavera/Oracle though maybe on Amazon you could get a few licenses of those still available for sale.
We use Suretrak but it is no longer sold nor supported by Primavera/Oracle. My clients would rather go with MS Project than with an Enterprise Solution full of bugs like P6 nor with their very limited companion products Primavera Contractor Standard/Deluxe.
I did some work for a local Program Manager for a Utility who would accept either P3 files from P3/Suretrak or MS Files, he was using infamous P3e, although having all sort of issues with the import of the files he would allow some choices. But come on, an enterprise solution for a windows replacement job?
20 years 10 months
Member for20 years11 months
Submitted by Andrew Flowerdew on Wed, 2009-05-13 10:48
As I said before, commercial decision time, whatever the rights and wrongs of the spec:
Kick up a fuss now and possibly be seen as a contractual and potential awkward contractor - and maybe the job goes elsewhere.
Keep quiet, get the contract and then try and change the software, but you’ve agreed to use the software by signing the contract so you’re not in the strongest of positions. You can still argue the spec is anti competitive, etc, and should allow other software, but it’s unlikely to be an argument that’s going to be settled overnight - not knowing the outcome, which software do you use?
No easy answer, should have been raised prior to tender submission stage.
As for your comment "my clients are not in the business of scheduling but in the business of Construction Contracting" - if they are construction contractors then they should very much be in the business of scheduling, it’s a fundamental part of their managmement job - although I think I get the gist of what you are saying.
21 years 8 months
Submitted by Rafael Davila on Wed, 2009-05-13 10:31
Float suppresion techniques are prohibited by these specs, I don’t know why, but it is ok with me, it should be enough that specs require your schedule to reflect your real action plan, this would be covered here and more. Seems like CPM specifiers’ have a tendency to complicate things above what is needed. Maybe that is why CPM has been discredited so much, instead of a usefull tool it becomes a burden.
We do not use float suppression as it will hinder true schedule, it most likely will backfire. We believe in being honest, in the event you have a valid claim don’t put it at risk by using those techniques.
I will comment only on the "float ownership" issue; which I understand that the Client specified its ownership to him.
This can be a very serious issue; in the future; from claims perspective.
To my knowledge; USA Government implements "Time Impact Analysis"; which is mainly based on the Critical Path(s) of the schedule. In your case; all the paths will be critical. Any minor delays in any activity (which normally would have a float in other schedules); will be translated into negative float in your case. Most likely you will be in delays throughout the whole project duration. Hence; any delays from the Engineer/Client side will either be parallel to yours (concurrent delays); or within your delays (no claim).
In your position; I will increase as much as I can the durations of my scope activities; and minimize the activities durations of the the Engineer/Client scope; as well as frontload their activities to the maximum. Such schedule may not be realistic or reflecting how you realy desire to sequence the works; and will have its negative impact on controlling the job. However you may be forced to schedule the project in this way.
Sherif
21 years 8 months
Submitted by Rafael Davila on Wed, 2009-05-13 10:18
Precisely, it is our money they are spending. Why Government is to leave out other suppliers from getting Government Jobs, the Government using their own money to rule them out?
Well our legislature issued the laws, federal procurement regulations are binding. Government agencies should follow the rules. Yes,there might be exceptions, that is why I am asking for bullets in both directions.
About planning software packages my clients are not in the business of Scheduling but in the business of Construction Contracting. They believe they must empower their managers to solve scheduling issues on the spot, at the jobsite in coordination with the subcontractors. They do not want to centralize scheduling. They have already spent time and money into training their managers to use the software of their choice. Specifying other software than what we use puts us at disadvantage.
20 years 10 months
Submitted by Andrew Flowerdew on Wed, 2009-05-13 09:48
Specifying a single product is against most public procurement rules I know of, but as I said, I’m not that well up on those in the USA. The reason being as you state, it’s anti competitive.
You said "The argument for integrating and tracking all projects I would accept it if in private jobs, not in public jobs". Why don’t you except that public bodies need to track and have a handle on their projects just like private companies? After all, it’s your money they’re spending!
If you’ve submitted your tender, YOUR OFFER, then there’s time before the contract is awarded to negotiate something different, but it’s something that maybe should have been raised before submitting your tender. Usual predicament now that tenders are in, would you risk losing the job by kicking up a fuss, ie, for the cost of buying P6?
PS: I have 7 different planning software packages on my computer, (4 of which I use alot), and no doubt will have to buy others at some point as the job requires it!
21 years 8 months
Submitted by Rafael Davila on Wed, 2009-05-13 09:17
Bids have not been opened yet. The specs are very dogy, call by product name, make and model, "later version of P3" (no longer sold by Primavera/Oracle), not open to other options.
My point is that the specs do not follow the federal procurement rules.
But I wanted to hear what could be their one sided arguments, to bullet-proof our arguments the same way the windows to be replaced are to be bullet-proof.
The argument for integrating and tracking all projects I would accept it if in private jobs, not in public jobs.
Would you change your accounting/financial software to SAP instead of Peachtree just because it fits their wishes?
Government should limit to ask for a Bar Chart if is not willing to follow the rules of procurement.
I won’t oppose for government to issue a standard for transfering electronic files any software vendor could supply without getting into the way of a free market. These standards should be issued with enough time for software developers to catch up. Maybe other type of specification would be in order, but Brand Specification for a CPM software, no way.
20 years 10 months
Submitted by Andrew Flowerdew on Wed, 2009-05-13 08:48
Not up on public procurement rules in the USA, in Europe it would very dodgy to specify one product - usually it would say something like "Primavera or other similiar approved".
But from their point of view, a government dept will probably have several projects on the go at any one time, hence they may use Primavera to track and integrate all the projects, (eg for cashflow). Hence why they specify it.
Are you at tender stage or has the contract been awarded?
If at tender stage you could ask the question, if the contract has been awarded then you could try and agree something different but at the end of the day in this case, that’s what’s you’ve signed up to, that’s what you agreed, that’s what you have to do if they wont agree something different.
21 years 8 months
Submitted by Rafael Davila on Wed, 2009-05-13 06:44
We don’t oppose for the Client to ask for a CPM capable software. But in public works procurement it should be the contractor’s choice . By specifying Brand Name it might be favoring a particular vendor, it might even lead to corruption practices when the specifier is paid by a supplier to leave out their competition. This is against the most basic principles of a free market.
We don’t oppose for the client to specify certain level of detail. We would oppose specifications that prevents the Contractor to have control over his own schedule and management methods by placing restrictions on how to handle the schedule in a way it hinders him to schedule his own plan. Well under this bid the specs go as far as specifying ownership of float preventing the Contractor of his right to build as per his plan, this restriction may create issues of resource availability.
When you read these types of specs you get the feeling that the specifier believes he is the only person capable of doing good scheduling practice, he is a moron. The Contractor needs a schedule to effectively communicate on the field, not to submit a thesis no one else will look. Well maybe the specifier should become a Contractor and put his eggs on the basket before he is allowed to issue CPM specs.
In this particular job, windows replacement on a government building, requiring the use of P6 would be like asking you to submit along with your personal tax return electronic files of your finances in SAP (an enterprise financial software) just because a $500 laptop computer can load the sofware.
Sherif I completelly agree with your approach, you are an open minded person, unfortunatelly the specifier for our job is not.
In my personal opinion; the Client should be asking for a CPM-capable software.
However; some Clients tend to include in their specifications; a certain degree of detail in the schedule (e.g. no activities with duration greater than 14 days; no activity costing more than 10,000$; etc. with minor exceptions such as long-lead items, etc.); in order to have more control over the schedule.
With such degree of details; where the schedule can be 10,000+ activities; you will find yourself restricted to use Primavera.
I agree with you that P6 has some bugs. Till now; I am facing 3 problems with it so far:
- Ability to print the calendars.
- Autosaving; which disrupts you while in the middle of work.
- Working hours per days which are not stored inside the schedule; but in the master database. If you define 8hr/day for a schedule; and define 10hrs/day for another one; then you open the 1st schedule and run it; dates and floats will be different. I am not talking about the calendars; but about the User/Global preferences for converting the days to hours; as P6 uses hours in solving the network.
Anyhow; try to start by agreeing with them the WBS; Activity Codes; Degree of details; list of activities; etc. which you can prepare in Excel.
Afterward; discuss with them what they are looking to get from the schedule; and explain that other software are able to carry out the job.
21 years 8 monthsRE: CPM Software Specifications in Government Jobs
R. Davila
16 years 7 monthsRE: CPM Software Specifications in Government Jobs
Sherif
Samer
17 years 3 monthsRE: CPM Software Specifications in Government Jobs
Dear Rafael,
Samer
20 years 6 monthsRE: CPM Software Specifications in Government Jobs
Sherif
Andrew
20 years 10 monthsRE: CPM Software Specifications in Government Jobs
Sherif
Sherif
Andrew,
Sherif
