Asta Powerproject Member for 6 years 10 months Member for 6 years 10 months Submitted by Dariusz on Wed, 2019-11-20 09:37 Permalink Hi Ben Thanks for that. This Hi Ben Thanks for that. This is exactly what I did: <Column name="DurationDays" datatype="Duration" group="Date" formula="If(IsElapsedTime(duration) = TRUE, Duration / '1ed', Duration / '1d')"/> Member for 13 years 9 months Member for 13 years 9 months Submitted by Ben Taunt on Tue, 2019-11-19 18:10 Permalink Hi Dariusz, There are Hi Dariusz, There are several potential solutions to this. The simplest is to add a column that tells you if a task is a Working or Elapsed: <Column name="ElapsedStatus" datatype="Boolean" group="Date" formula="IsElapsedTime(duration)" /> Cheers, Ben @ Powerproject Member for 6 years 10 months Member for 6 years 10 months Submitted by Dariusz on Mon, 2019-11-18 14:26 Permalink Hi MikeThanks for reply and Hi Mike Thanks for reply and warm welcome ;) It's not about Asta Powerproject itself but BI Controller. These elapsed durations you could see in screenshot are OK, my entire plan contains days and elapsed days. The problem is coming when I want to export Powerproject data to external datasource. For example I've got 2 tasks: Task 1 , 2d duration Task 2, 2ed duration Model files has formula for duration and it "force" to write durations in days: formula="Duration / '1d'" But for Task 2 it will return incorrect value becasue of elapsed units... With formula: formula="Duration / '1ed'" it will return correct values for durations expressed in elapsed days (Task 2), but not for working days (Task 1). Still with me? :) I can't find any way to export correct durations via BI Controller regardless of duration units used for tasks. Member for 19 years 10 months Member for 19 years 10 months Submitted by Mike Testro on Mon, 2019-11-18 13:03 Permalink Hi Dariusz - welcome to Hi Dariusz - welcome to planning planet. Right click the duration table - select Format Cells - Left click Duration - select your format "Day". Best regards Mike T. Log in or register to post comments
6 years 10 monthsHi Ben Thanks for that. This
Hi Ben
13 years 9 monthsHi Dariusz, There are
Hi Dariusz,
Ben @ Powerproject
6 years 10 monthsHi MikeThanks for reply and
Hi Mike
With formula:
Still with me? :)
19 years 10 monthsHi Dariusz - welcome to
Mike T.
