You could do this simply using Code Libraries. Create a Code Library for your units, and then set that as a single select option. Add the Code Library as a column and a drop down with your options will appear...
Also means you can then easily filter and sort etc.
13 years 9 monthsHi Chris,You could do this
Hi Chris,
Ben @ Powerproject
