Hi Dean
I guess that you are working on version 14+
Asta have changed all tutorials to the on line knowledge base. http://support.elecosoft.com/index.php
If you have a full support licence the link will tell you everything.
24 years 9 months
Member for24 years9 months
Submitted by Vladimir Liberzon on Tue, 2017-02-21 12:07
Line of Balance means that the diagram shows what activity shall be done at what place and at what time.
You wrote about a housing project and suggest to show at the left (Y axis) the houses and time scale as X axis. Do I understand you right? It looks like the Gantt Chart and not Time-Location.
Please clarify.
Vladimir
8 years 9 months
Member for8 years9 months
Submitted by DGConstruction on Mon, 2017-02-20 17:16
Yes it is reletively simple to set up a line of balance view straight from the bar chart.
It works as a time - distance chart similar to Tilos.
It works on the Bar reference and the Task reference for each plot number.
Place each task on the same linear Plot Number bar and label accordingly.
This is all explained in the tutorial section.
You will find it very useful for linear projects.
One tip - Once you have set up a typical plot number copy and paste for all of them and then use the cross plot link system to set up all the links in one tap.
19 years 10 monthsHi Dean I guess that you are
Hi Dean
24 years 9 monthsHi Dean,I do not understand
Hi Dean,
I do not understand your requirement.
Please clarify.
Vladimir
8 years 9 monthsHi Mike Many thanks for
Hi Mike
Many thanks for taking time to respond.
A couple more questions......if you mind?
You make ref to a tutorial, I can't seem to find this, could you please guide me to this?
Also, you make ref to a new view, is this shown in the guide?
Many thanks in advance for your assistance
19 years 10 monthsHi DeanYes it is reletively
Hi Dean
