Thanks Mike, the only problem I have with that method is if I copy a task and it copies the code to the new task even though it's not allocated to the hammock of the original task. I wasn't sure if there was any other way of showing that the new task is not allocated to a hammock without doing it manually.
9 years 4 monthsHi Richard,You can use the
Hi Richard,
You can use the parent name colun which is found under the identification category.
Hope this helps :)
19 years 10 monthsHi Richard.Just change the
Hi Richard.
Just change the code of the new task.
Mike T.
9 years 6 monthsThanks Mike, the only problem
19 years 10 monthsHi RichardAssign a code to
Hi Richard
Assign a code to each task and then assign the same code to the hammock.
Mike T.
