Publishing an Asta Programme
18 years 5 months
Thanks Ben.
I've gone with the Asta Viewer, but it's a shame the viewer users can't select information from the spreadsheet (e.g. to select, copy & paste into excel).
Chris
13 years 9 months
Hi Chris,
Can you persuade them to use our free Project Viewer?  That would allow them to navigate through the views in the project that you have set up.
Or if they already have 'another' product, you could chose to save your Asta programme in the relevant file type.
Saving to HMTL might also be another option; it can give you a version of the programme that can be read within any browser.  You can set it up so that different projects are navigated via the browser.  But I don't think you can save multiple views into one HTML file.
If the Gantt view isn't important to them, the alternative could be to simply dump into Excel.  You could set up your Tabular Reports to mirror the column data that you have in your various views.  Once you've set up Tabular Reports once, you won't have to manually copy/paste into Excel each time there is a change.
Ben @ Asta
