The default is "by name", I choose "By sort order", then fill the sort order field in the library explorer. That gets me to the same sort order as P3s
I could not get the view the way you suggested, maybe I did not explain clearly what I was trying to do.
This may sound stupid but I dont seem to find how to copy/paste code library definitions from PP. While I investigate it, can you explain me how do I sort the grouping according to a field?
Im trying to achieve the exact same sort order in PP that I use in Primavera. Why? Because thet will help me learn how to configure the views in any way that is needed. That will also show me the limits and differences between PP and P3.
I think I need to explain it better what im trying to achieve. The next image is the contractual view in P3:
16 years 5 monthsRE: Sorting Code libraries
Mike: thanks for teaching me your way of doing things.
Im glad we both learned something new.
Best Regards.
Carlos A. Matus.
19 years 10 monthsRE: Sorting Code libraries
Hi Carlos
Thanks for teaching me something new.
I have never had to use that facility before.
Mike Testro.
Thanks for the replies Mike!
I found another way to make it:
tools > options... > view > sort code libraries.
Thanks for the help.
Regards.
Hi Carlos
You do not copy paste the code library - you copy paste the task descriptions.
Then add the line numbers from P3 and do a =vlookup on the Powerproject side.
You will find the User Field Manager under the Tools drop down.
Save the file first and make sure that you set the User Level under the Help Drop Down to Advanced.
Thanks Mike.
http://www.flickr.com/photos/8317996@N03/3962193329/sizes/o/
in P3, Headings are grouped according to the activity code Value, descending.
This is the view Im getting in Power Project:
http://www.flickr.com/photos/8317996@N03/3962194661/sizes/l/
Hi Carlos
One simple way would be to set up a spreadsheet
Copy and paste the P3 descriptions in column A and a list of numbers representing the line numbers of the P3 programme in Columnn B.
In column C copy paste your PowerProject descriptions and in column D do a =vlookup formula to align the P3 line number to PwerProjct descriptions.
In powerprojec set up a user field column and copy paste the line numbers into it.
Then sort ascending on the user field.
Save the view as P3 Sort.
