Edit activity description text
6 replies [Last post]
Rajesh Varma
User offline. Last seen 4 years 19 weeks ago. Offline
I would be thankfull if anyone can suggest me a method to edit the text of activity description, so that it automatically gets changed in the whole program,wherever the same description appears. Hope the querry is clear.
Raj
Anbin Ponnith
User offline. Last seen 9 years 17 weeks ago. Offline
Hai
Try to Filter the Activity you want to Change&Organise the activity to a single Level.Edit the activity Description in First Cell
Select Edit->Fill Down
Anbin Ponnith
Santhosh kumar Na...
User offline. Last seen 7 years 30 weeks ago. Offline
Global change is the right one. There wont be any problem in doing that. Or else try to export to excell
Tools>Project utilities>Export. Select the required field you want to export and select file type as WK1 or WKS. Complete you all eidit, etc in excell then import back.
Rajesh Varma
Hi Gary,
Yes, that is the best option.
Raj
Gary Whitehead
User offline. Last seen 6 years 6 weeks ago. Offline
Another option is to set up a normal filter showing only those activities you want to change, type in the new description in the top activity, use your mouse to highlight all activities in the filter, right click and select ’fill cell’
You say you’re not able to set up a filter for activity description -why not? what problem are you encountering?
Rajesh Varma
Hi Gary,
Thanks for your response. I tried,but not able to set up a filter for activity description and change tab under global changes will not allow typing a long text,which is my new description.
Raj
Gary Whitehead
If you want to replace the entire description for a new description, you can use a global change (tools, global change)
It’s a fairly self explanantory process -you basically set up filter and a new description, and it overwrites the decription for all activities that satisfy the filter.
There’s a ’trial run’ option I suggest you use to make sure it works as planned before making the change for real.
