Why does Progress % does not apper while summarizing
Haresh Jayanth
User offline. Last seen 7 years 12 weeks ago. Offline
Why does, while we are summarizing the project with wbs level , any progress % (for eg activity % complete column), does not show any % at WBS level , even when we add resource & cost for all activities.
The summarized % column is blank....
Can anyone explain......
User offline. Last seen 17 weeks 5 days ago. Offline
Haresh,
There are only two fields that would not summarize total in summary band, Physical % complete and Activity % Complete which is represented by Performance % Complete.
There are 3 types of % complete type, Duration, Unit and Physical. Duration is base on duration (Yr, Mth, Wk, Day or Hr), Units is labor, non-labor and material and Physical = Physical.
All three of them are represented by Activity % complete and Performance % complete (which ever is set on % complete type) therefore if total is required in summary band Performance % Complete should be used and if not then Activity % Complete is the appropriate to use.
To show the total in Summary Band, under Group & Sort -> Display Option tick Show Group Total.
