P6 v7 Resource histogram display
Roger Booth
User offline. Last seen 5 years 9 weeks ago. Offline
In previous versions of P6, when showing the resource usage histogram, you used to be able to show an average value per bar by checking the box in "Resource Usage Profile Options". Since upgrading to v7, checking this box doesn’t seem to work and the scales are shown as full values. I am just missing a trick here or is it something that has been changed.
Tansel Kermen
User offline. Last seen 7 years 11 weeks ago. Offline
Hi, I am using P6 v7 SP2. It works properly.
Just for your info.
Tansel
Arnold Puy
User offline. Last seen 10 years 3 weeks ago. Offline
You are welcome Roger. Absolutely yes.
Roger Booth
Thanks Arnold
As you say it works when on the cost but not units. Hopefully it will get fixed in SP1
Roger
Arnold Puy
Hi Roger,
As far as I know, this is a bug with P6 v7. If you tick the Cost and go to Graph Tab then change the value of "Divide interval totals by" then it works fine.
Arnold
