Importing progress percentage not working
14 replies [Last post]
kier legard
User offline. Last seen 15 years 8 weeks ago. Offline
hi to all,
Im using p6 and im updating my schedule by importing it to excel and updating and exporting back to p6.The problem is when I update the duration percent complete it is not updated when imported to p6 .What seems to be the problem.
regards,
kier
Arnold Puy
User offline. Last seen 10 years 2 weeks ago. Offline
Hi Hady,
Equal or not equal, still you have to filter or use the "If Paramaters" if you are going to use the global change.
The easiest way is to show the % complete type on the column.
Regards.
Hady Shendy, PMP
User offline. Last seen 12 years 27 weeks ago. Offline
Hi Arnold
your method may enough if the % were equals.
Arnold Puy
Hi Hady,
Even without utilizing the global change, you can easily change the % complete type by showing them into column and use the command fill down.
Regards.
Hady Shendy, PMP
try to create user field, when export to excel be sure to add that field
in excel use it as your % completion
in P6 use globel change to convert that field to Duration or Physical duration.
Arnold Puy
I don’t think so...
Luca Basile
User offline. Last seen 10 years 1 week ago. Offline
Groups: TILOS
Wow
you think that with the new version they improve and make the planners life easier instead ...
May be in PM7 the opportunity will be back
L
Arnold Puy
Hi Luca,
Yes, I have tried all the PCT fields in P6 and export to Excel. All of them having the (*) next to column title.
Have a nice day too.
Arnold
Luca Basile
Groups: TILOS
did you try to export all PCT fields and see which one has not the * near by?
Is how I have done to find out which one I could use for my update
Sorry for the missunderstanding on PM5-PM6.
Have a nice day
Luca
Arnold Puy
Hi Luca,
I forgot about PM5 but if you have done and it works for you then it’s fine. However, in P6 it doesn’t work. Anyway, thanks for the info.
Arnold
Luca Basile
Groups: TILOS
I just done a progress update on PM5 this morning, using "’Activity % Complete(%)" and worked
May be in PM6.2 this field is not locked
L
Arnold Puy
Hi Luca,
You just mentioned the asterisks (*) in the heading cannot be imported. However, "Activity % Complete" also has.
How can you export back to P6? Can you tell us?
Arnold
Luca Basile
Groups: TILOS
from excel you have to import back the "Actvity % Complete"
All other PCTs that have an * near the headings are not importable back in Primavera Enterprise
L
Arnold Puy
Hi Kier,
You need to change your remaining duration: Because Duration % Complete equals to (OD - RD)/OD*100.
Where: OD is taken from the current plan & not from the baseline.
HTH.
Arnold
P6 Support
User offline. Last seen 15 years 41 weeks ago. Offline
Duration % complete probabaly not a field that is importable. Any field that has an asterisks in the heading cannot be imported.
