change of WBS when Importing P3 to P6
James bid
User offline. Last seen 10 years 10 weeks ago. Offline
Good Day Planners!
May I ask your help regarding my problem in importing because whenever I import a program from P3 to P6, The Project ID at P3 automatically included in WBS code at P6. here what was happened...
in P3
Project ID Project Description
CP00 Construction Project 00
WBS(sample only)
BCA Briton Construction and Partners
in P6 (after importing)
WBS (sample only)
CP00.BCA Briton Construction and Partners
All the "CP00" was added to all WBS Code of the Project..
May I know what was the problem.
Thank you
Chris
Dieter Wambach
User offline. Last seen 7 years 31 weeks ago. Offline
Chris
View Activities: You have the columns
- WBS; shows the complete hierarchy
- WBS Name; Shows the name of that WBS-node
- WBS Path; Shows the code without the upper nodes
For you WBS Name or -Code I assume then it will be shown with each activity.
Summary lines: Group & Sort: Group By WBS, unmark: Show ID Code
James bid
Thanks Dieter!
May I know how to hide the WBS Code? or just say Show only WBS name.
Because what the problem is upon I imported the program with the project ID CP00 to P6 The WBS was turned to CP00.BCA instead of BCA only
Dieter Wambach
Chris
This is by design. The first level of the WBS is the project itself. If You’ll show the WBS, the complete path will be shown. Alternative: Just show WBS-Name.
