Loss of WBS Name when importing into P6 from MS Excel
Matthew Edwards
User offline. Last seen 2 years 49 weeks ago. Offline
I am importing an MS excel file into P6. I have no issues with this.
However, when the excel file is imported, the WBS Name chages to the Master file name.
I cannot sort and filter the WBS in P6 as the WBS is lost.
Any help and suggestions would be appreciated.
Matthew Edwards
User offline. Last seen 23 weeks 3 days ago. Offline
glad I could help
Matthew Edwards
Thanks Zoltan. !
the first part of ALL wbs structure is ALWAYS the name of the Project ID this is what makes the activity id unique so that you can link different projects together that have the same activity id.
If the activities are already in there then just export them with the correct wbs
if the activites are not in there but the wbs is the easiest way to do this change the name of the projet to a single letter like the letter M
then when you add the activity the wbs will be M.whatever
hope this helps
