Critical Path - Graph like S-Curve
Jhorbam Baena Orozco
User offline. Last seen 3 years 46 weeks ago. Offline
Hi everyone.
I have to make the graph of the critical path but in a lineal type of graph like s-curve...how i can do that in P3 or excel?...i need a good explanation please...is urgent!!!
Thanks...
Hi Vishnu...sorry but the requeriment was ask to me bad...the people that ask it only need the S-curve but they have a wrong idea.
thanks
Sreejish Vishnu
User offline. Last seen 12 years 32 weeks ago. Offline
Groups: GPC Qatar
Hi Orozco,
I dont know if I understood your requirement correctly. Let me put it this way, - you need to have the critical activities one after the other arranged in terms of the early start/ finish dates.
This can be done by
1.Format - organize - Select activity data item - then remove all items under heading ’group by’
2.Under sort by - selct early start or early finish - order by ascend or descend
3. go to filter - and select the critical activities with the condition you have for the criticality (total float less than 5 or total float = 0 or whatever)
This will give you all critical activities listed one after the other.
I’m not sure whether this is what you are looking for.
Shah. HB
User offline. Last seen 1 year 45 weeks ago. Offline
Hi Orozco i am not sure about P3 but could do in a spreadsheet by selecting the activities respective durations followed by early dates .Generally this sort of procedure is called line of balance
